Corsair TX750W replacement ?
bru
bru
21 Oct 2002
kent
I've Got a Corsair TX750W and the fan in it has started making a load of noise. After taking it apart I see that it all looks to be in good order but the fan has obviously seen better days, the bearing makes a perceptible grinding noise when turned by hand, so I'm not surprised it makes a racket when powered. It is probable not long for this world before it stops altogether.
So the question is do I just replace the fan, which is easy to do and I assume that due to the currant fan just being two wires it will not just run a new fan flat out all the time but the PSU itself modulates the voltage for speed control.
Or do I bite the bullet and replace the 6 year old unit (yes I checked, bought it from here 10th dec 08 for a whole £69.99 :))
I was looking at the following possible replacements.
YOUR BASKET
1 x EVGA SuperNova G2 1000W '80 Plus Gold' Modular Power Supply £119.99
1 x EVGA SuperNova G1 1000W '80 Plus Gold' Modular Power Supply £109.99
1 x Corsair CS850M 850W Semi-Modular 80+ GOLD Certified Power Supply (CP-9020086-UK) £99.95
1 x EVGA SuperNova G2 750W '80 Plus Gold' Modular Power Supply £79.99
Total : £409.92 (includes shipping : ).
Yes I know there is no superflower in there, but then again aren't the EVGA's the same minus the LED's ?
Currant PC spec, x58a with i7 920@4GHz ( just about to be replaced with a xeon 5650 which will be clocked as high as it will go), single 970 ( quite possibly to be doubled up on soon) 6 HDD, SSD, dvd, fan controller, watercooling pump (D5) and 5*120mm fans, 2*230mm fans.
I know I probably don't need that big a PSU, but then we don't all need 5GHz CPU, multi GPU, 16GB+ ram, huge monitor....etc..etc..etc but we want it :D
I had 4.5y old TX650 die on me (luckily 5y warranty and didn't damage other parts), so no, I would not recommend a fan replacement.
Ok So it definitely going to be a replacement, but the question now remains which one?
The EVGA 750w G2 is the obvious choice as it is a direct replacement for the outgoing TX750.
But back when I bought the Corsair TX750, I was thinking about being as future proof as possible. then I was running a [email protected] and a GTX260, which seems like so long ago now.
q6600 105tdp GTX260 182tdp
xeon 5650 95tdp GTX970 145tdp
Obviously everything is overclocked :D but things haven't really changed that much (even though the Maxwell's are showing some impressive savings over the previous kepler GPU's) I nearly went for SLI 670's but I'm not sure that the 750w would have been comfortable enough with the i7 920@4GHz with SLI 670's and everything else.
So with that being said is 750 going to be enough for the next 6 years
or is it worth spending the extra £30 now for the 1000w G1 or extra £40 ( which I suppose is 50% more) for the 1000w G2 just for the 10 year warranty?
My currant power usage while running prime and heaven together.
So a new 750w PSU could do SLI 970's but could it do SLI big Maxwell's or even Xfire 390x's or who knows what in the future.
Don't want to have to buy another until it needs replacing, but then it is another 50% more.......:confused:
Comments please.
I just checked some SLI GTX980 reviews and these cards are ridiculously power efficient. Most reviews have total system load at around 450w. For total load with a pair of cards that's extremely low. I can make my pc pull more than that and the gpu isn't even clocked!! With that in mind the 750w G2 would still be more than enough. Not sure about 390X or whatever AMD's next cards are going to be. If I was running a pair of 290X cards now I would want 850w as they are so power hungry. If you are sticking with Nvidia and are still not convinced and want the 1000w for the extra (unneccessary) headroom then yes, I would pay the extra for the G2 unit with the 10 year warranty.
So in one breath you say 750w is enough, then another that you would want 850w, yet another that 1000w is unnecessary. :confused:
Still not sure what's best, probably the 750w but I just know I will be kicking myself if in a year or so it turns out to be not enough.
To clear up what I was trying to say.
If you are sticking with Nvidia then the 750w G2 is more than enough even for SLI 980's. In this case ignore the comments below.
I have no idea what AMD's next gen are going to be or if they will be as power hungry as the current gen, but if I was running a pair of 290x in crossfire I would want a minimum of 850w as they just pull so much power.
If you are still not convinced and want a 1000w psu anyway then the 1000w G2 is worth the extra tenner over the G1 for the warranty.
Ok cheers, that makes more sense now.
I think I'm just being a bit paranoid, 750 has been fine for the last 6 years, so I'm sure it would be fine for the next good few.
Just bought myself the other day a EVGA SuperNova 1200W 80 Plus Platinum. This will be replacing my old HX850w which is also making loads of noise (sounds like a diesel generator!)
I thought it would be better to go overkill on it and future proof myself for 10 years.
One thing that to me is important thats worth noting is I think its better to have a bigger power supply for your needs, even if you only use half the rated load (or under) the psu will be not working nothing like as hard as a smaller psu, so cooler temps and less fan noise. Hence the reason I went for 1200w. ;)
