Hi there,
I've just built my first ever gaming rig, and everything seems fine apart from a sort of fizzing noise coming from my Corsair TX850V2 PSU. It sounds a bit like when you half pull out a kettle lead out of a socket and it crackles, but quieter and constant. It some times becomes silent but will restart up again soon after.
I've read online that these PSU's components sometimes interact with frequencies generated by certain systems creating a high pitch squeal, but i'm not sure if that's the same noise I'm getting.
Is anybody familiar with this issue? If it is the combination of the Corsair and my system causing this noise, could somebody suggest an alternative PSU from a different manufacturer of equivalent quality?
My system specs are:
Intel Core I5 3.3ghz
ASUS P8Z68-V Pro/Gen3
16GB Corsair Vengeance DDR3 RAM
2TB Seagate Baraccuda HD
120GB OCZ SSD
2GB ATI Radeon 6970
Corsair TX850V2 PSU
Coolermaster 690 II Advanced Case
Many thanks,
Alex
120GB OCZ SSD
2GB ATI Radeon 6970
Corsair TX850V2 PSU
Many thanks,
Alex
