Corsair Vengeance Products... (NO GIBBO NOT MEMORY!)
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys.
We have the new Corsair gaming range available to pre-order with stock likely to arrive next month.
Corsair Vengeance M60 5700dpi Laser Gaming Mouse @ £69.98 inc VAT
You get maximum precision and response from the Avago ADNS-9500 LaserStream™ Gaming Sensor, even on high resolution displays. Outpace and dominate opposing players with less accurate or slower gaming mice.
Superior ergonomics and a dedicated sniper button will make the M60 laser gaming mouse your favorite weapon of mass destruction. It's functional design and soft-touch surfaces are comfortable in your hand, even for extended hours gaming sessions. The dedicated sniper button automatically lowers your DPI so that you can quickly adjust your aiming precision and precisely locate shots.
A unibody aluminum frame is the secret behind the M60's low weight, high rigidity, and optimal mass distribution. It also has three adjustable tuning zones, allowing you to customize your mouse's weight to have just the exact feel you want.
When the action is fast and furious, you are constantly moving and repositioning your mouse. The M60's lift detection provides high precision tracking and reliable cursor placement even when lifted off of the mousing surface.
Tune the performance for your desktop surface by choosing between four response times — 1000Hz, 500Hz, 250Hz, or 125Hz (1ms, 2ms, 4ms or 8ms).
The solid metal, rubberized scroll wheel doesn't just feel great — it gives you the precision you need when selecting weapons. Precise tactile feedback and accuracy help make sure that you select the right weapon every time.
- 5700 DPI — Avago ADNS-9500 LaserStream Gaming Sensor
- Adjustable DPI in 100 DPI increments
- 1000Hz/500Hz/250Hz/125Hz (1ms/2ms/4ms/8ms) selectable response time
- Tracking up to 165 inches per second, up to 30g acceleration, and automatic frame rate control
- Adjustable lift distance — five selectable levels to fit your play style
- Surface quality detection
- 8 individually programmable buttons
- Side mounted sniper button provides user settable DPI change while pressed for enhanced precision targeting
- Comfortable ergonomic design with soft-touch surfaces and grip improving textures
- Omron left and right click switches rated for eight million operations
- Aluminum metal frame and base for improved rigidity and mass distribution
- Solid metal, weighted scroll wheel with rubberized scroll surface for improved finger traction control and feel
- Ultra Low Friction PTFE pads for smooth performance and accurate gliding
- USB Connector with gold plated contacts
- 1.8m lightweight non-tangle cable
Only £69.98 inc VAT.
ORDER NOW
Corsair Vengeance M90 5700dpi Laser Gaming Mouse @ £89.99 inc VAT
You get maximum precision and response from the Avago ADNS-9500 LaserStream™ gaming sensor, even on high resolution displays. Outpace and dominate opposing players with less accurate or slower gaming mice.
The 15 fully programmable buttons are arranged and tuned for intuitive operation without compromising your grip. You get almost effortless access to your frequently-used abilities, macros, button combinations, and spells. Keep your focus on the game, and not the buttons.
The strong aluminum frame is the secret to low weight, high rigidity, and optimal mass distribution. The texturized, soft-touch surfaces are designed for comfort even after extended hours of gameplay. In short... it's designed to simply feel right.
Create up to 50 profiles and share, import and export macros with the Vengeance gaming mouse software. It's a free download at corsair.com.
Play multiple games, with multiple character types? Store up to 6 profiles in memory on the Vengeance M90 laser gaming mouse, so you can easily save your character profiles, favorite macros and frequently used keys. Enjoy the convenience of always having your profiles and preferences even if you switch PCs.
Instantly adjust DPI for precise control when quick changes are needed between different sensitivity settings... all with the simple touch of a button.
When the action is fast and furious, you are constantly moving and repositioning your mouse. The M90 includes lift detection provides high precision tracking and reliable cursor placement even when lifted off of the mousing surface.
- 5700 DPI Avago ADNS-9500 LaserStream Gaming Sensor
- 1000Hz/500Hz/250Hz/125Hz — 1msec/2msec/4msec/8msec response time — user selectable
- Tracking rate of up to 165 inches per second, up to 30g acceleration, automatic frame rate control
- Five selectable levels to fit your play style
- 15 programmable buttons
- Nine ergonomically placed, side-mounted programmable buttons
- 48KB of on-board memory for storing up to six "on the go" profiles with active profile LED
Only £89.99 inc VAT.
ORDER NOW
Corsair Vengeance K60 Mechanical Gaming Keyboard @ £99.98 inc VAT
Cherry® MX Red key switches are the best of the best — they provide the sensitivity and low operating force that professional gamers love. Reaction times are ulra-fast and responsive for quicker double and triple taps. The action is predictable and linear unlike lesser gaming keyboards that have a tactile bump or the annoying click of a typist’s keyboard.
The Vengeance K60 is designed to give you complete control even during the most intense action. The contoured, textured WASD and #1-6 keys are soft to the touch and without slip so you can focus on the game without needing to look down to find the right controls. An extra set of standard typing keycaps and a keycap replacement tool are provided for general typing.
Our expertly designed anti-ghosting technology provides flawless control even when you're pressing multiple keys at once. The K60 has individual switches with dedicated diodes for each switch so every key press results in an input and is 100% ghost free without tradeoff or compromise.
Typical USB gaming keyboards are limited to the USB standard six-key rollover. The K60 features increased performance with a 20-key rollover implementation on USB at a blazing fast 1ms (1000 reports per second) reporting rate.
The comfortable yet rugged design is ideal for single player or LAN party gaming and provides increased durability and stability when compared those that are primarily plastic. The stiff suspension chassis and the laser etched keys are made for durability so they won’t degrade over time.
- Light, responsive Cherry MX Red mechanical switches for fast, efficient gaming action
- 45g actuation Force
- 2mm to actuation and 4mm to bottom
- Rated for 50 million operations
- Gold contacts
- Ten (10) additional sculpted FPS keys (W, A, S, D and 1 to 6) for superior reaction and control — interchangeable with the standard keyboard keys Gaming palm rest with soft-touch surface for superior gaming comfort
- Storage for ten (10) sculpted FPS keys
- Key extraction tool included and storable in palm rest
- Six multimedia keys — Stop, Previous, Play/Pause, Next, Mute, Volume Up/Down — with Solid metal, weighted volume "drum roller"
- Windows Lock key for uninterrupted game play
- Metal top plate for increased strength, durability and rigidity
- USB pass-through connector giving easy access to a USB port on the back of the keyboard (USB 2.0/1.1/1.0)
- Selectable report rate: 1000Hz/500Hz/250Hz/125Hz (1ms/2ms/4ms/8ms) response time
- 2m non-tangle cable
Only £99.98 inc VAT.
ORDER NOW
Corsair Vengeance K90 Mechanical Gaming Keyboard @ £109.99 inc VAT
Easily access to your most frequently used macros, presets and key combinations even during the most intense action. You can record up to 54 programmable functions accessible from three separate banks, ideal for grouping macros by function, or access. Macros can be created on-the-fly, customized, and activated with a single keystroke.
Our expertly designed anti-ghosting technology provides flawless control even when you're pressing multiple keys at once. The K90 has individual switches with dedicated diodes for each switch so every key press results in an input and is 100% ghost free without tradeoff or compromise.
Typical USB gaming keyboards are limited to the USB standard six-key rollover. The K90 features increased performance with a 20-key rollover implementation on USB at a blazing fast 1ms (1000 reports per second) reporting rate.
The rugged aluminum chassis provides increased durability and stability compared those that are primarily plastic. The stiff suspension chassis and the laser etched keys are made for durability so they won't degrade over time. And the K90 has over 90 LEDs that provide outstanding illumination even in dim light.
Create up to 50 profiles and share, import and export macros with the Vengeance keyboard gaming software. It's a free download at corsair.com.
On-board memory lets you take it with you
36Kb of memory built into the K90 lets you take your customizations and profiles with you and use them on any system.
- Light, responsive Cherry MX Red Mechanical switches for fast, efficient gaming action
- 45g actuation force
- Gold contacts
- Three banks of eighteen G Macro Keys with Macro Record and Bank Select hot keys
- 36Kb of onboard memory for storing up to three sets of eighteen G keys for gaming on the go
- On-the-fly, macro recording
- Laser-etched, backlit keys with four illumination levels (off, 66%, 75%, and full illumination) selectable from the keyboard
- Six multimedia keys — Stop, Previous, Play/Pause, Next, Mute, Volume Up/Down — with Solid metal, weighted volume “drum roller”
- Adjustable feet tilt for optimum personalization and positioning
Only £109.99 inc VAT.
ORDER NOW
Corsair has really expanded their product range...
ram, PSU, heatset, CPU coolers and fans, and now mouse and keyboard as well...
Are they gonna be making monitors, drives, graphic card and motherboard next? :p
