Corsair Vengeance RGB 64GB (2X32GB) DDR5 PC5-44800C36 5600MHz Dual Channel Kit - Black (CMH64GX5M2B5600C36)
4 Jul 2024
UK
This runs perfectly at 5600mhz. What is the fastest speed I can overclock these to that would be stable? Also, I've never overclocked anything manually i.e. I'm one of those that like to click the button to safely auto overclock and that's it.
personally I never overclock memory, as I understand it you can overclock if you do looser timings, and the overclock you can get isn't much anyway. Not like a CPU where it could be +1ghz.
Leave it at stock XMP/EXPO timings and overclock CPU instead.
I see. It might be best to just leave things as is then.
