corsair vs550 vs cx500?
22 Mar 2014
Plymouth
Any ideas on which powersupply would be better for gtx 960 + i5 4590k cpu? I'm really on tight budget and not sure if I should skim on psu?
i have the corsair vs350 currently powering this:
i3 4160
asus H81M-Plus
8gb 1600mhz
gtx 750 non ti 1gb(ive overclocked it slightly)
optical drive
toshiiba 1TB hdd
2x case fans
was a pre-built system from elsewhere and was brought as a gift about 4 months or so ago and while its not causing me any issues especially where there been times ive left it on for 24hrs or maybe tad more, if i had the choice i wouldve got a better psu, just for the simple fact the vs is the bottom and worst range.
never had an issue with a cx430 which i did choose to buy earlier in the year(sold with computer back then too).
As pastymuncher said, avoid both. Both cheaply made and personally nothing I would ever use in a system
