- 11 Jul 2011
Hi all,
As above really, I’m just starting my first PC and watercooled build and can’t work out how to connect the temperature sensor cable.
I don’t have a commander pro as I’m running Lian Li infinity fans so using the controller that came with them.
My motherboard is an NZXT N7 B650E which also doesn’t have the correct header.
Is there some kind of adaptor cable I can buy? Any help would be greatly appreciated!
