I've recently setup a new build with the following memory and motherboard:
Corsair 4GB Kit (2x2GB) DDR2 800MHz/PC2-6400 XMS2 Memory Non-ECC Unbuffered CL4(4-4-4-12)
Gigabyte GA-MA790FX-DS5 790FX
Although I've not overclocked before I need some advice. The SPD for the memory within the BIOS is showing timings of 5-5-5-18 rather than those stated for the XMS. Firstly can anyone provide me with detailed manual timings that would need to be used for this MoBo (latest BIOS release) so I can run the memory as intended please?
Secondly the POST shows the memory as 'unganged' mode. I'm using slots 2 and 4 which, as far as I can tell should enable dual channel mode (ganged?). Within the BIOS there is an option for 'Ganged' or 'unganged' but neither actually change the POST from unganged. Am I missing something, I've tried slots 3 and 4 rather than 2 and 4 with the same effect. I cannot use slot 1 because the scythe cooler blocks access.
