Corsair XMS2 Dominator CMD8GX3M4A1333C7
Permabanned
28 Mar 2011
Space Man INIT
To be run with a AMD Phenom II X2 555 Black Edition that unlock to an X4
It's £110 delivered
Corsair XMS2 Dominator CMD8GX3M4A1333C7 RAM Module - 8 GB (4 x 2 GB) - DDR3 SDRAM - 1333 MHz DDR3-1333/PC3-10600240-pin DIMM
Internal memory 8192 MB
Internal memory type -
Form factor DIMM
Bus clock rate 1333 MHz
CAS latency 7-7-7-20
Memory layout 4 x 2048 MB
Number of pins 240
Product Type RAM Module
Manufacturer Part Number CMD8GX3M4A1333C7
Manufacturer Website Address corsair
Manufacturer Corsair Memory
Product Model CMD8GX3M4A1333C7
Product Name XMS2 Dominator 8GB DDR3 SDRAM Memory Module
Product Line XMS2 Dominator
Brand Name Corsair
Form Factor 240-pin DIMM
Number of Modules 4 x 2 GB
Memory Speed 1333 MHz
Memory Size 8 GB
Memory Technology DDR3 SDRAM
Memory Standard DDR3-1333/PC3-10600
Standard Warranty Lifetime
You can buy 8GB of 1600MHz RAM from OcUK for less than £70.
The faster speed will make up for the slacker timings or it will likely run at 1333MHz with tighter timings.
It's AMD so faster is not really going to help! Plus i was going to use an ek block on the Dominator
So what's the question then?
I've read your other thread and also found it hard to answer as you don't list/state what it is that you want to use the system/memory for.
If it’s for max speed, without any benefits, other than benching this needs to be established as costs become irrelevant.
But if it’s for general gaming/apps use then the specification of the memory will drop dramatically in price - but not necessarily in performance for day to day usage.
Basically, what’s your need/criteria for the whole spec?..
