- 8 Apr 2012
- North wales
1) Leave it as it is, or
2) Try and get it running at the next highest speed (833 or 866 or whatever it wants to do)
If you go for option 2 then you may need to up the DRAM voltage from 1.80V as you'll be overclocking the RAM.
Perhaps try 1.85V and see where it gets you.
You may also need to loosen the timings if you can find the settings in the BIOS.
I can't see where they are in the user manual.
i tryed 833 and hangs on windows logo and wont start few couple mins
also tryed 400 mhz x 8 on cpu so i could get 800mhz dram but same again.
think ill leave it as it is for now till my north bridge cooler comes and then maybe ill try push a little more out of it
