Corsair XMS2 Voltages
6 Apr 2010
Cambridgeshire
Hey All
I am running Corsair XMS2 2 x 2Gb. I cant find if my standard voltages are 1.8V, 1.9V or 2.1V. CPU-Z says 1.8V, but in the BIOS they show as 1.9V but some places on the internet say its 2.1V...
I have no idea :P
Can anyone shed any light? So you all know its the ones with the purple stickers and again CPU-Z says its 5-5-5-15.
Thanks
EDIT: Just to add something. I am currently testing at 904Mhz I think it is at 2V. Thats only +0.100V in the BIOS which leads me to believe its 1.9V default but that doesnt agree with anything on the internet.
its the PC6400. So 1.9V is stock? Is it ok me running 2.0V though? I am only running that voltage because I either run under 800mhz or over 800mhz at the moment. If I reach 3.6Ghz I will be running 1:1 ratio so might be able to put it down to 1.9V again.
