Had my comp for a bit now and got myself some new corsair xms3 1333 (2x 2gb) to go with my old XMS3 2x2gb ram.
Well had it all working but had some other problems with the new SSD not been compatible with my mobo??? or something like that. (EVGA nForce 790i Ultra SLi3) and the H100 not working/fitting/breaking so just been running one stick of ram for while been problem solving.
Any way now I have found out it was the SSD making all the problems and now removed that from the system, and got windows 7 back working I went to put all the ram in and it does not seem to work with all 8gb and will only start up with only 2 sticks (2 new or 2 old) but not all 4
both types of ram are corsair xms3 with same timings and everything but I cannot work out why its no longer working when 4 days ago thay were.
It gets to the loading windows screen then restarts the comp. Pull out any 2 sticks and it works.
Quite sick of the comp now after spending £300 on new bits and non of them work
Q6600
nivdia GTX260 x2
win 7
Q6600
nivdia GTX260 x2
win 7
