Corsiar h70 cooler?
you should be able to use the 1156 bracket I think I read on here. if you have it, the h50 1156 will fit so assume the h70 1156 will :)
From Gibbo
Sandybridge is compatible with all 1156 heatsinks and is the ATX standard so all current cases and power supplies are fine.
Just ring, email Corsair and ask them to send you a new plate, may cost but it'll be worth it.
