Can someone who owns or recently bought a Cosmos 2 tell me if :
1. the fan controller issues fixed. On the CM support forums there was a lot of dissatisfaction with how the fan controller caused 3rd party fans to make strange noises on low settings. And it wasn't fixed in the 2nd revision of the controller.
2. the front 230mm fan be replaced with a 200mm megaflow fan ?
3. the Cosmos 2 handle 180mm height coolers (thinking Phanteks with 140mm fans slightly raised).
thanks
thanks
Build quality is great apart from the controller. It's real easy to add side fans to the door, I put two of the plain black 120's from the case that I replaced with Spectre Pro blues on the door, reduces temps a couple of degrees I found.
