No, I'm not using the Cosmos 2 as a water closet, I want to know if anyone out there runs this monster with a 'thicker then normal' Radiator.
I got the tape measure out last night and measured my.. Radiator and fans, The radiator alone I think is about 60mm. Is this too much? Maybe even 80mm with the fans on. If so I might need to do some major work to the top of the case to either squeeze my radiator in with fans outside on top or to either try get my radiator into the top compartment and run the tubes in the back!
Cheers,
Dr Peirson
Cheers,
Dr Peirson
