hi all just obtained a coolermaster cosmos pure case and a corsair hydro 80 cooler, the case manual seems to say, that the airflow for the case is from the front to the back.
ok the thing im confused over is, the manual for the hydro 80 says, pull air in from outside the case, wont this cause negative pressure, inside the case and logically should i, have it pulling air in the same direction of the rest of the case ?
any advice welcome
any advice welcome
