Cosmos S Side Fan
15 Jun 2008
Considering a Cosmos for my next upgrade...could someone help with a few Q's please...
1. How loud is the fan?
2. Any problems with it transmitting noise/vibration into the side panel / case?
3. Can it be reversed? For example if I have a roof mounted 120.3 rad sucking in air.
Thanks.
Thanks.
1 pretty quiet, about 800 rpm iirc
2 no
3 yes, you have to dismantle the side panel to get to it but its only 4 screws
