Hello all
I'm looking to get a new kitchen fitted and I've had three quotes from who I think are reputable fitters. One is £6,500 and the other two are almost identical at £4,900. I've already turned the first one down as it's way out of budget.
The kitchen is pretty small:
and here's the rough design that the quotes are based on:
The three quotes involve parts from Howdens. The third fitter has also quoted for a local supplier of german kitchens (same price) which he says are better quality than Howdens efforts.
The second two fitters are charging £2000 and £2,200 respectively for labour, including everything (remove and dispose of old kitchen, fit units, worktop, tiling, flooring and decorating).
Does this sound reasonable to you, for a kitchen of this size?
