- 17 Mar 2004
Does anyone know the work involved in fitting a LSD. The Quaife do one for under £600, just wondered on the cost of fitting etc.
it involves dropping the box and taking it apart
Budget for around £200/£300 fitting. Least thats what it costs on the astra, not sure if the Focus gearbox is harder to remove.
Just out of interest does the diff lock hard so to speak?
I tend to leave the traction control button alone, too. It’s super-effective and does seem to manage the torque and slip with all the control of a limited-slip diff. In some respects it’s slightly better because you don’t get the torque-steer sometimes associated with an lsd (although there’s more tug as the tyres wear down). Turn off the system and the lack of a diff is all too apparent. Use all of the torque and the wheels spin-up very quickly and understeer skates you across the road. It’s a frustration that such a well-balanced chassis almost demands you leave the electronics dialled-in to manage the slip. The best of both worlds would be the sophisticated traction control married to a mechanical lsd – just like the previous Cooper S. I wonder when a diff will appear on the options sheet?
exactly, a rear diff should be a doddle to drop down. theyre having you on
