Costa latte glasses for tassimo machine?
27 Mar 2013
Nottingham
As the title says i need some glasses for my tassimo machine for the costa lattes. The standard ones i bought are too small sadly. Any ideas?
It tells you on the back of the pack what volume the Costa lattes are, just buy mugs/glasses of the same or greater volume. :)
I ended up getting a range of sizes of Bodum glasses - the 0.45l one is just big enough for the Costa lattes. It was a massive struggle to get anything big enough!
Where did you both get the glasses from? Really 0.45L only just fit? you sure you dont mean -0.35? The drinks are 330ml apparently. Where do you guys get all your pods from too? Is amazon still the go to? Havent had to top up in a while.
The foam will go over the top of a 350ml glass, I had a set of 350ml, 250ml and 80ml glasses that were fine for everything including the other lattes, but had to buy the 450ml once they started selling the Costa lattes.
I tend to buy mine from Tesco when they're on offer or Tassimo's webshop.
