- 13 Jul 2017
Anyone seen this issue with this model of psu.
Installed new power supply on 12/July/2017. Powers up ok from power switch on pc. All peripherals run ok
Windows 10 and Linux all run without power issues.
Only issue is the power supply will not drop power once the o/s is closed down. All fans left running. Power supply fan still running.
PSU will not power off when pressing or holding same power on/off button. Forced to drop power via switch on power supply or from mains. Check and cleared Bios / Cmos / rebedded cables etc. Still same issue.
Tried psu on another known working system. It did the same on that system. Any suggestions apart from return it would be helpfull. Also reported via warrenty to Cougar. They are useless and never reply. So so much for warrenty support.
PSU connected to a Gigabyte GA970-UD3 motherboard with 8350 8 core AMD cpu
Not an o/s issue since it will not power down even when in bios setup mode.
