** COUGAR LX & VTX POWER SUPPLY RANGE - AVAILABLE FOR PREORDER **
OcUK Staff
26 Nov 2014
Stoke
Now available for preorder, we have a couple of new ranges from Cougar: -
LX Series - Fully modular 80+ Bronze certified units with HDB fans & DC-DC power conversion technology. These are some of the very few fully modular Bronze units on the market. We have 500W & 600W available initially, and these are due in at the start of June.
VTX Series - Aggressively priced 80+ Bronze certified units with a 3 year warranty and a temperature controlled 120mm fan. These are pretty well priced for what they offer and would provide a stable and reliable base for a mid ranged system. We have 400W, 450W, 550W and 700W available initially, with all but the 700W due at the start of June (700W will be end of June).
cougar vtx 400w 80 plus bronze power supply - black @ £33.95 inc vat
introducing the cougar vtx series of power supplies, aggressively priced units which provide reliable 80+ bronze certified performance. each vtx power supply is equipped with a quiet 120mm temperature controlled fan, various protection circuitry and pci-e 6+2 pin connectors as standard.
the vtx series is an ideal product for anyone looking for reliable yet well priced power supply for a mid ranged system. all vtx units are backed by a 3 year warranty for peace of mind.
features
- 80 bronze certified, up to 88% efficiency
- supports the newest specifications of atx12v
- 3 year warranty for peace of mind
- supports pci express 3.0 next generation vga cards with 6+2 pci-e connectors
- quiet & temperature controlled 120mm fan fitted as standard
- optimatal air-dynamic design, leading to a more silent operation
- non-stop high performance and full rated wattage 40 degrees ambient temperature
- compliant with erp lot 6 2013, energy consumption in standy is <0.5w
- compatible with energy star 5.0 systems
- full protections including ocp, scp, ovp, uvp, opp
connectors
- 1 x 20+4-pin atx12v/eps12v
- 1 x 4+4-pin atx12v/eps12v
- 1 x 8 pin eps12v
- 1 x 6+2-pin-pcie
- 4 x sata
- 3 x 4-pin-molex
- warranty: 3yr
only £33.95 inc vat.
order now
Cougar VTX 450W 80 Plus Bronze Power Supply - Black @ £36.95 inc VAT
Only £36.95 inc VAT.
ORDER NOW
Cougar VTX 550W 80 Plus Bronze Power Supply - Black @ £41.99 inc VAT
Only £41.99 inc VAT.
ORDER NOW
Cougar VTX 700W 80 Plus Bronze Power Supply - Black @ £51.95 inc VAT
Only £51.95 inc VAT.
ORDER NOW
Cougar LX 500W 80 Plus Bronze Full Modular Power Supply @ £54.95 inc VAT
The Cougar LX series are a range of fully modular 80 Plus Bronze certified units aiming to offer great features with a competitive pricepoint to match. The LX series are all equipped with 120mm HDB fans for quieter and more reliiable operation, along with full modular support, a feature rarely seen on Bronze units. The LX series boast a minimum of 2 x PCI-E 6+2 connectors as standard, with single rail operation for stability whilst gaming.
The Cougar LX also uses DC-DC power conversion technology for regulation of stable voltage outputs.
The Cougar LX series is an impressive combination of valuable features, reliable operation and competitive pricing, giving you everything needed to power a mid ranged gaming system comfortably.
Features
- Compact size - only 140mm in length, fits a majority of systems
- Fully Modular - Connect only the cables you need for less clutter & better airflow
- HDB Fan Powered - Hydro Dynamic Bearing Fan, extended durability & lower noise levels
- Fan Curve fine tuning - advanced technology for better cooling quality
- Impressive operation at 40 degrees ambient temperature
- 80 Plus Bronze Certified - reaching efficiency of up to 88%
- Compliant with ErP Lot 2013 - Energy consumption in standby is <0.5W
- Support for Multi-GPU technology - Suppoerts PCI Express 3.0 VGA cards with 6+2Pin PCI-E connectors.
- Ultra Stable Voltage Outputs - DC to DC technology for enchanced voltage stability
- Single +12V DC Source
- Strong safeguards including OCP, OPP, OVP, UVP & SCP
- Optimized Over Current Protection - Your components will operate stably and be protected from harm.
Connectors
- 1 x 20+4-Pin ATX12V/EPS12V
- 1 x 4+4-Pin ATX12V/EPS12V
- 2 x 6+2-Pin-PCIe
- 2 x 6Pin-PCIe
- x SATA
- 3 x 4-Pin-Molex
- Warranty: 3yr
Only £54.95 inc VAT.
ORDER NOW
Cougar LX 600W 80 Plus Bronze Full Modular Power Supply @ £60.95 inc VAT
Only £60.95 inc VAT.
ORDER NOW
