- 5 Apr 2008
sorry i meant 1.425
Takes about half an hour per block. You can get by with 10 minutes though. It's worth it and makes them look all shiny.
To me it seems daft buying expensive watercooling kit and not lapping it. There's 3-8 degrees in it usually. And if yours is scratched then it could be sitting uneven.
Nah, it's not the water. Check for any kinks in the tubing though.
