Could anyone help with this watercooling question please?
2 Jan 2009
I have the Dtec Fusion 2 pump for my setup with a Quad core insert. Is there a right and wrong way to fit it? thanks guys.
Abit IN932X-MAX Mboard, Intel 6850 Quad Core Extreme
OCZ PC2-6400C5 Dual Channel Vista Gold Series Ram 8Gb
2 300gb sata Hard Drives, 2 NEC DVD re-writer drives
1 Samsung 1TB spinpoint hard drive
Coolermaster 1000W PSU, x2 BFG 8800GTX Overclocked and Watercooled
Thermochill 3 Fan Rad + Laing Pump with XSPC clear top + XSPC Drive Bay and 1/2" Tygon Hose running 2 GPUs
Thermochill 1 Fan Rad + Aquaero Pump + Aquatube Res + 10mm Hose running CPU
All controlled via Aquaero monitoring system running Vista 64bit
Samsung T260Hds x3 using Matrox TH2GO
Logitech Z5500 Speakers
Logitech MX5500 mouse,G15 keyboard and G25 Steering Wheel
You mean D-Tek FuZion II CPU block? Yes, there is a correct orientation - they usually suggest the outlet pipe goes to the highest point to prevent air blockages and the quad-core insert sits across the cores. If I remember correctly, in your S775 system the divider should be horizontal in a vertical case, but it joggles around as you fit it, so it's a bit of a fiddly job.
Ok thanks, so does this mean that as it sits in the case vertically the quad core insert will allow the flow to the left and right, not the top and bottom of the core then? Cheers.
