I've got the machine built.
Condensed list of what i'd guess are the need to know components are:
Vista Home Premium 32 bit
Gigabyte GA-MA790x-DS4 Mobo
AMD Phenom II X4 940 Black Edition 3Ghz quad (stock)
4GB (2x2Gb) Ocz reaper RAM
Well here's my problem.
My problem is that on the System window in the Control Panel it lists the processor as an unknown model at ~2.3Ghz when it clearly is a 3Ghz quad core 940. From the Vista score and performance i've had i can guess that this is just a cosmetic thing but i think this might make overclocking a little tricky if i can't rely on the systems reports of its settings. So i was wondering if
a) Anyone knew what was wrong.
b) If anyone knew how to fix it.
c) If anyone had any experience overclocking this processor. Little bit of a newbie when it comes to overclocking.
http://img15.imageshack.us/img15/1364/cpuzsystemscreenshot.jpg
Screenshot of CPU Z and the Control Panel System reading.
I have a dxdiag i can send anyone if they need it to help and they likely will.
Thanks in advance,
Chivalry
Edit: sorry if this turns out to be the wrong board to post this in.
Thanks in advance,
Chivalry
