Hi
I recently started planing full watercooling for my system and I found a problem.
I want to install full cover waterblocks, preferably acetal, on my 2 Evga gtx 660 ti's however EK configurator sais they are not compatible. I crosschecked that with other sites ( videocardz.com and anandtech.com) and I found out that my card has identical PCB to gtx 670 reference cards and should work with waterblocks designed for them.
The card I have is currently being sold at OCuk clearance lines if you want to check it.
So, any chance EK could be wrong about this?
Thanks in advance for all your advice
Cheers
BH
Cheers
BH
