Could I chuck these in my current build...?
24 Dec 2011
I have a Z68ap-d3 with 8GB of kingston hyperX the 2*4GB @ 1600mhz kit.
I just found two old sticks that i was wondering if I could chuck in, they're 1GB 1333mhz might even be DDR2 I'm not sure; they have no identifiable numbers or anything.
Would it even work? I'm just wondering before I throw them out...
yeh DDR2 won't fit and if its slower speeds I wouldn't mix and match anyway. Would probably have negative effects on performance anyway
