Could I get some upgrade advice
13 Jan 2015
Hey guys,
This is my first post, but I have been lurking on this board for a while now. I would appreciate your advice on how best to upgrade my system. I am pretty new to all this and my build below was my first and basically chosen for me by a friend. I have had a look at some of the other threads but would appreciate your advice on where to spend my money and what to upgrade first.
Recently my gaming has tended to be on older titles I get in a Steam sale so my lower spec PC has coped fine. However, with all the great games coming out at the moment, I think I need to get ahead of the curve! I tend to play RPG/ open world games like the Elder Scrolls (modded to death) but have been known to dabble in FPS and other genres. I am looking to get Fallout 4 (+likely mod it) and suspect now is the time for an upgrade.
Below is my specs, let me know if I missed anything out.
I was thinking a budget of £300 but if it's worth spending more to get bang for my buck, I could be convinced!
thanks for your advice,
Processor (CPU) Intel® Core™i5-2500k Quad Core (3.30GHz, 6MB Cache) + HD Graphics
Motherboard ASUS® P8Z77-V LX: USB 3.0, SATA 6GBs, ATI®CrossFireX
Memory (RAM) 8GB SAMSUNG DUAL-DDR3 1333MHz (2 X 4GB)
Graphics Card Sapphire HD6670 2GB DDR3 Graphics Card
Hard Disk 1TB 3.5" SATA-III 6GB/s HDD 7200RPM 32MB CACHE
DVD/BLU-RAY Drive 12x BLU-RAY ROM DRIVE, 16x DVD ±R/±RW
Power Supply 450W Quiet 80 PLUS Dual Rail PSU + 120mm Case Fan
Processor Cooling INTEL SOCKET LGA1155 STANDARD CPU COOLER
Sound Card ONBOARD 6 CHANNEL (5.1) HIGH DEF AUDIO
Razer Deather Adder Mouse
Logitek gaming keyboard
24" 1080p Dell monitor (I forget the type but its about 7 years old)
Hi and welcome.
My first suggestion would be to get a new GFX card.
Depending on which card you get and what PSU you have now (can you name the make+model?) you might also need a beefier PSU.
What resolution do you game at?
Definitely upgrade videocard and PSU first though.
If your budget allows it. SSD and aftermarket cpu cooler.
Thanks for the responses!
I game at 1980x1080 so long as the performance holds up. I think my PSU is FSP, but once I head home after the xmas break I will check the model.
Sounds like I should go for the GTX 970 + a new PSU then aim for SSD once my bank balance has recovered from christmas
Don't forget an aftermarket cpu cooler, it'll give your already unlocked cpu some more life ( if you fancy overclocking ). Many guides out there already.
