Hey guys, just following up a thread i made about a graphics upgrade which sorta turned into an everything upgrade: http://forums.overclockers.co.uk/showthread.php?t=18287810
I just want to clarify the uses of this machine because i only want stuff that i actually need and not go over board. My monitor is 30 inch so everything i run will be at 2500x1600 res. I use photoshop a lot for art n stuff and also need to be able to run my wacom tablet which acts as another monitor. I do run games n stuff but not as much as id like to unfortunately so its just casual play. Mainly stuff like wow, sc2 but i'll prob check out some of the newer FPS games.
I'm trying to keep as much of my old parts as i can but please let me know if they also need changing, especially since they're all about 3 years old and i dunno if they'll be compatible.
New stuff:
CPU: Intel i5. I have no idea which i5 i should go for, tbh i cant make sense of the different models. Would really appreciate if someone could suggest one.
the ones ive seen are about £145/160
GPU: eVGA GTX 570 Core: 732MHz, Memory: 1280MB 3800MHz GDDR5, Stream Processors: 480, Shader Clock: 1464MHz.
In the above thread the gtx480 and gtx570 were recommended. I've been researching them a bit and it seems they both give the same performance but the 570 runs cooler. Since im pretty sure my last card died because of overheating (my apartment is pretty hot most of the time) i think i'll go with the 570. I choose eVGA cuz of HDMI/displayport compatibility/price/warranty.
- £237
memory: Corsair XMS3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz. - £60
Hard drive: OCZ Agility 3 120GB SSD. I've never used an SSD before, this seemed like a good choice. - £170
OS: Windows 7 64 bit (i dont know if i need 64bit or 32, prices seem the same) - £70
Old stuff:
Mobo: P5Q-PRO
memory: 4gb
case: HAF-932
PSU: corsair 750w
Total price seems to be around £690. its a bit steep so id be happy to downsize anything thats not really needed.
Sorry for the long post!
New stuff:
- £237
Old stuff:
Mobo: P5Q-PRO
memory: 4gb
case: HAF-932
PSU: corsair 750w
