Could I push a bit more??
23 Jul 2007
Hi all,
Currently running my Q6600 under water on a ASUS P5Q Pro. Here is a screenshot of what i've got at the moment:
Do you think I could run any faster considering my voltage and temps?
Cheers
Your temps are a good ten, fifteen degrees below where I would worry. The voltage is fine up to 1.5V, a fair few people ran the 65nm quads at 1.6 under water.
Yeah. Fair bit of headroom there. Unless you're already hitting significant diminishing returns I'd keep going.
That looks like a pretty decent chip, iirc mine required 1.4v for 3.6ghz, needed a very sizeable leap to just over 1.5v for 3.8ghz though.
