Could I push it a little more???
10 Nov 2011
Telford
Right first attempt after i have re-done my water loop at overclocking the cpu and gpu's.
I managed to get the CPU to 4.055GHz on 1.4V
GPU's running at 900 / 2200 @ 1.88V.
CPU temp doesn't go above 55C when stress testing and gpu's didnt even hit 50C.
How much more can I up the volts on the CPU and GPU's?
Since I'm bored I looked at Google for you.
AMD say don't go over 63c on your core temps and general concensus appears to be that 1.5v is OK so that would suggest you still have some room left on your CPU.
NVidea say dont go over 97c on your GPU and it looks like most folks reccomend 1.05v with some straying to 1.1v by all rights yours should be fried by now so I guess there's a typo (1.08v)?
oops yeh lol its 1.088V.
What about max voltage on the cpu can I up that any more or do u thik it will fry it?
As per my original post you still have some headroom left on the CPU as the recomended max appears to be 1.5v with some pushing a little more using water. Google tells me these chips can do 4.2 though of course this is dependant on the chip.
