and no i don't OC it... should I?
I would say yes, K series CPUs are designed for OCing. Don't do it with the OEM Intel fan/cooler though.
Someone else here should be able to advise on your PSU for OCing.
sorry mate, just had a look and it looks to be this one! http://www.xigmatek.com/product.php?productid=179&type=featureIf it is the one you have just linked to, then you should be fine with a GTX 970 as it provides 39A on a single rail.
But that one has two 12v rails, one at 19A and one at 18A!
So I doubt it is that one! The OCP (over current protection) would be kicking in with your current card.
When you get home just have a look.... it is pretty easy to tell. Thinking about it now, your one probably does have only one rail with enough amps on it... if a dual rail 12v 500w is around 19/18A on each rail.
But, it is best to be totally sure and have a look on your actualy psu.
