could i ...
A less ideal (but possibly cheaper) solution would involve using a TV sender/Magic Eye device (this gives you remote functions though). Basically coax out from the box either direct to the laptop TV tuner (i'm assuming you have?) or scart out from the box to TV sender, then remote TV reciever TV in on laptop. This can work well but it depends what you want and how much you want to spend.
