Could my settings be wrong?
Man of Honour
29 Mar 2003
Blurton
In July 2007 I built a new system based around this -
Intel Core 2 Quad Pro Q6600
Gigabyte GA_P35_DS3R
GeIL 4GB (4x1GB) PC6400C4 800MHz Ultra Low Latency
I came over from a P4 3.6 system and to be honest I was disappointed and I still am.
An example is that I've just been unraring and its going at a good speed.
I then load Microsoft Outlook and the unraring slows to a crawl and it takes Outlook ages to load in.
As soon as it loads in it goes back to speed.
I then click on Firefox and again it slows until Firefox is loaded.
I've put up with this for over a year but surely it can't be right!!!
My P4 3.6 definitely does multi-tasking waaaaay better.
Any suggestions?
Make sure drivers are all setup properly.
Have you run any benchmarks to see if it performs as it should in them?
If you want it to always prioritise the rar, you could set the priority of the task in task manager to above normal, but you're right that it should multi-tast better than it seems to be doing. How much RAM do you have, and how good is your HDD? Is your RAM all being used when you try and open things whilst doing it? It may be that your cpu isn't the limiting factor.
XP with SP2
Running chip at stock
WD Raptors
No problems in my System > Device Manager
Standard fan that came with CPU
Hmmmmm -
Temperatures:
Motherboard 66 °C (151 °F)
Aux 46 °C (115 °F)
GPU 95 °C (203 °F)
WDC WD800JD-00LSA0 31 °C (88 °F)
WDC WD4000KD-00NAB0 44 °C (111 °F)
WDC WD4000AAKS-00TMA0 46 °C (115 °F)
Cooling Fans:
CPU 3392 RPM
Voltage Values:
CPU Core 1.14 V
+2.5 V 2.00 V
+3.3 V 3.38 V
+5 V 5.03 V
+12 V 3.14 V
If that 66 is the motherboard that is quite hot. Could be the CPU? Which is still hot but better than the motherboard being 66. I reckon the 46 is the motherboard which is hot.
What did you use to take that reading,what does your bios say it is.The only accurate way of taking a foolproof reading is with a multimeter.
But if you use a few different ways of checking ie in the bios,whatever software gigabyte provides,everest and they all say that 12volt line is low then you have got problems with you PSU
