Could some kind soul help?
28 Dec 2009
Wales
I have a flash banner I need to use on my website. It's causing me no end of grief. Used natively it won't display on ios devices. Wrapped in an iframe I can get round that but then I have problems linking and all sorts.
I was wondering if some kind soul had 5 mintutes they might be able to convert the flash banner into an animated GIF image? I would certainly owe you a pint if so!
edit: I ahve CS 5 but following the guides online I can't seem to export the banner as a GIF. Pulling my hair out now!
You don't happen to have the fla file? That's what's really needed it's pretty easy to do then, all you need to do is export it as a .gif
You could re-create it and export it as a gif but that would take a little while, or there are some converters out there from a quick google however they seem to leave watermarks...
