Could some od you amd experts help.
28 May 2007
Saturn’s moon Titan
Hi peeps I'm going for a new amd 9800x3d setup could you guys check my specs this is only for gaming at 4k..
AMD Ryzen 7 9800X3D Eight Core 5.20GHz (Socket AM5) Processor - Retail
SKU PRO-AMD-03517
Quantity: 1
£539.99 £479.99
fiber_manual_record
In stock
Asus ROG STRIX X870-A GAMING WIFI (Socket AM5) DDR5 ATX Motherboard
SKU MOT-ASU-03087
Quantity: 1
£370.00
fiber_manual_record
In stock
Kingston FURY Beast EXPO RGB 32GB (2x16GB) DDR5 PC5-48000C36 6000MHz Dual Channel Kit - White
SKU MEM-KNG-02963
Quantity: 1
£124.99
fiber_manual_record
In stock
Arctic Liquid Freezer III ARGB White High Performance CPU Water Cooler - 360mm
SKU COO-ARC-01993
Quantity: 1
Hi.
Your choices are fine.
There are cheaper white motherboards so mite be worth looking again to make sure your happy.
To note.
The arctic freezer 3 has a thicker radiator than most at 38mm so with a fan in total you need a clearance of 63mm if fitting at the top of your case
I have the nzxt h9 i have a artic freezer 360 in there at the minute thank you for the reply..
First boot on AM5 can take up to 15mins for anything to show on screen and may reboot a few times this is because the motherboard is training the memory so be patient.
That RAM is expensive and CL36 isn't ideal. You should be looking at 6000mhz CL30.
It's white ,RGB ,expo and it's Overclockers anything else C30 that matches that is the g skill which is pre order.
C30 to c36 will be miniscule in terms of performance.
The AF3 may not be compatible with the X870-A unless you remove the top M.2 heatsink.
The Gigabyte X870E aorus pro ice and MSI X870E Edge TI wifi both appear to be compatible if you want a white board and don't want to change the cooler.
Life saver what about the
SAVE 2%
Lian Li HydroShift LCD 360TL AIO CPU Cooler 360mm - White
Hadn't realised how limited OcUKs stock is. Performance difference is small but I'd still resent paying a premium price for CL36 RAM. For that money you can get the latest CL28 bin.
All I want is a stable system for gaming guys would like a tidy case thats why I like the lian li aio ..
FYI: you really don't an AIO for that CPU, a freezer 36 or peerless assassin would be sufficient.
ASRock's X870 Pro RS did well thermally in HUB's roundup and is one of the cheaper boards and white.
