Could someone help point out fan header connections on motherboard?
15 Apr 2020
Probably a really silly question but it's my first build and can only find one fan header as it is listed CHA_FAN2 just underneath the connection, I've circled in read the fan header that I'm currently using. Thank you in advance
Motherboard:
Bottom left:
Bottom right:
You could just plug it (extra fans) into the PSU with an adapter thing, but you won't have any control over it (will run at full pelt) unless you buy a resistor cable or have a fan controller hub.
