Howdy,
I understand most things bout overclocking... but I am still a bit confused on one with with clocking RAM?
I understand timings, thats all good... but the actual clock speed I don't get?
For example, my last PC took DDR PC3200 and was labelled as 400mhz. But when I was clocking it I had to keep its around 200mhz... I had it as 220mhz. So what I am confused about is all these numbers? 3200, 400mhz... so where does the 200mhz come from? Why wasn't I suppose to clock it to 400mhz+ opposed to 200mhz+?
Was it cos I had 2 sticks, so 2x 200=400mhz? Or is it some maths where you basically have to half it?
My new PC has GeIL 2GB (2x1GB) PC6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC) so I assume I would have to keep this to 400mhz+ right? Or do I have to clock this to 800mhz?
Please help me with this cos I am confused?
also whilst I'm here, if I say got my timings to 4-4-4-12 1T and got that stable at the stock mhz speed... would that mean that those timings would run fine with any stable clock speed? I'm asking cos I would set my timings up first, once I have those stable I would then start clocking the speed of the ram... if it dies would I know its the speed change/DDR volt that is killing it? Or could it be that the DDR will run fine at that speed, just it doesnt like those timings at that speed? Does that make sense?
Please explain anything you can about RAM overclocking... I need help!
thanks
thanks
