- 26 Sep 2008
Hi I hope somebody can give me a bit of advice. I have been getting various BSoDs since I upgraded my cpu and mobo at xmas. I thought it was due to a faulty cpu and returned it but the new one that has come has also got the same problem.
My system specs are-
Vista 64 with SP1
Asus M3N78 mobo with latest BIOS and drivers
AMD 9950 BE
Asus ATI 512mb 4750 with latest drivers
2x 2 gig OCZ "vista upgrade" RAM
2x 160 g HDs
I havent overclocked any of them
Hiper 580W PSU
I threw the list of the old BSoD messages out because I thought the new CPU would fix it, but there have been many different all seeming to centre around memory issues.
In the problem Reports and solutions screen it says-
"You received this message because a hardware device, its driver, or related software has caused a blue screen error. This type of error means the computer has shut down abruptly to protect itself from potential data corruption or loss. In this case, we were unable to detect the specific device or driver that caused the problem."
So I am a bit confused as to whether its a hardware or software problem. The crashes normally happen when gaming although this can be 2S arcade games or latest FPS. Have tested heat on cpu and gfx card using a number of apps like speedfan, rivatuner, hardware monitor and others and they are all well within guidelines. It does occasionally happen when just browsing too so doubt it would be a gfx card problem
Whilst RMAing my processor I put my previous 6000x2 in and had only the odd crash compared with every couple of hours with my 9950. The crashes started when I first installed the mobo/cpu and was using vista 32, I have upgraded to 64 bit since then. Have tried rolling back gfx drivers.
I have a feeling it maybe the RAM is not compatible with CPU or mobo but do not have any spare sets to swap and cant really afford a new set just for a month or so. What else could I try to narrow the problem down and what RAM should I go for when I get paid.
Have thought it could be the PSU with it working with the less power hungry 6000x2 but again dont really wanna be spending money on something that isnt going to sort it.
Thanks advance
Vista 64 with SP1
AMD 9950 BE
2x 160 g HDs
Hiper 580W PSU
Thanks advance
