- 30 Nov 2014
- Thatcham in Berkshire.
I was considering getting a vertical rider cable for my p600s, cause I think it looks amazing. But I assume there zero benefits apart from that?
My gpu at the moment is directly under my noctua d15. The fans literally push down on the card and the cooling fins are extremely close. I didn't know if any heat was being transferred because of this.
So (and I know it's a long shot ) I wondered if vertical mounting could actually reduce temps or at least be roughly the same if moved away from a hot air cooler?
It's a 2.5 slot card so would be fairly close to the glass,w I assume would be far worse than being a bit close to the d15. Just curious. And also want to justify vertical mounting lol.
