Could you boot an OS from a flash drive?
26 Apr 2008
York
As above. My cd drive in my laptop has decided to pack up. Could i do this? If not any other suggestions?
Yes you should be able to adjust your bios settings to boot from a USB device. Any linux distro can do this, I always recommend Ubuntu for ease of use.
yes you can install vist or xp off usb stick you can even install xp to to usb stick.PE bulder i think its called or use the asus ee install method.
I know you can boot from them, jus wondering whether you can load windows off it?
Oh right, it's just your title said 'Can you boot an OS' which I assumed you meant anything and not windows specifically.
Windows PE is usually the best bet for booting off USB, google should reveal plenty of tutorials.
