Hi
I have been having a problem for over 12 months now with Counter Strike, I have just done a re format on my pc and still having the same issues. The problem only happens with CSS all of my other games work without issue, can play CODWAW2 max setting no problem, also play GRID no problem
To try and fix the problem I Re Installed Windows 7 + Drivers
Installed Steam
Installed CSS
Installed Call Of Duty MW2
Turned HDR off in video settings
The issue I have is the game will freeze/lock up I can look around with the mouse though I can not move, some times the screen tears or has a jerky movement to it. The game countdown clock in the top right corner still continues to count down, this last for approx 2 to 5 secs (by which time I am dead)
See PC Spec below
PC Spec
Intel Core 2 Duo E8500 LGA775 'Wolfdale' 3.16GHz (1333FSB)
Tuniq Tower 120-LFB CPU Cooler
Asus P5Q Deluxe
OCZ 4GB (4 x 1GB) PC2-8500 1066MHz Reaper HPC Edition Dual Channel DDR2
eVGA GeForce GTX 285 SSC Edition PCI-Express 2.0
2 x Seagate Barracuda 7200.10 500GB ST3500630AS SATA-II 16MB Cache RAID 0
Western Digital Raptor 150GB WD1500ADFD 10,000RPM SATA 16MB Cache
Creative Sound Blaster X-Fi Platinum Fatal1ty 7.1
Corsair HX 620W ATX2.2 Modular SLI Compliant PSU
Antec P180 Advanced Super Midi Tower Case
Dell Ultrasharp 2407WFP 24" Widescreen LCD Monitor
Razer Tarantula Advanced Gaming Keyboard
Logitech G9
Creative Fatal1ty Gaming Headset
Windows 7 Ultimate 64bit
2 x Noctua NF-S12 800RPM 120mm Silent Case Fan - 3 Pin
3 x Antec 120mm Silent case Fans
_________________
Thanks for taking the time to reply
Installed Steam
Installed CSS
See PC Spec below
PC Spec
Asus P5Q Deluxe
Logitech G9
_________________
