Counterstrike source - reset defaults?
7 Feb 2004
There are a couple of files that you can delete and they reset your settings for your game on counterstrike but i can not remember where they are.
I need to change the default of the resolution as it is stuck on an unsupported version and I can not get it to start.
Anyone know?
THanks
Delete anything ending in .cfg in your cfg folder... should be a cs one, config.cfg and perhaps some user ones e.g. usercongif.cfg
Hope this helps :)
