Counting names and email addresses in Excel
2 Aug 2005
I thought I'd put this in here because it more likely to be a macro issue in Excel.
I've got a spreadsheet with lots of names and email addresses in grids. These are spread across several workbooks, each being a different department. What I want to be able to do is, if a name or email address occurs in the worksheets more than a set amout of times for this to be either flagged up or highlighted. Does anyone know if this is possible?
Any help appreciated
Thanks
Merge all sheets, in a blank column from top to bottom put a 1 value in that column, pivot the thing and take it out to a new sheet, add a filter, ignore the 1 counts...
