Couple of 3870x2 questions
23 Jun 2004
Blackburn
Probably gonna be ordering one of these cards tomorrow all going to plan but just wanna double check a couple of things
Will the card work in my 965 ds4 board?
My psu just has 2x 6 pin pci-e connectors, will this be ok or do I need 8 pin connectors?
Thanks
You don't need the 8 pin connector unless you want to overclock, the option is unavailable in CCC if you use two 6 pin connectors. Apart from that the card will run fine.
