I used the yellow ones SATA 0 - SATA 3 on mine...not sure if thats itell or not..cant remember. But you can use eigther. To use the ones after 0-3 I think you have to install additional drivers.
Use the power straight from you PSU for the graphics card!
i used yellow for my system drive and purple for my data, windows kept losing my data drive on the purple ones so i put them both on yellow and not had any probs since
