- 19 Feb 2011
Hi all need some help if possible please
Just put together my new rig which includes an Antec 920 Kuhler, Zalman z9+ case and Asrock Ex4 Gen3 mobo.
Everything went into the case fine after some moving of fans, the issues I'm having are,
1) Kuhler is spinning, lights on, software's installed ok, but the software is reading 0rpm on the fans and pump? Is there a setting in the BIOS I needed to switch off?
2) Z9 case, I have 2 fans plugged into the fan controller, but neither of these fans are powering on, I've checked the cabling a few times and all looks good, all the moles connections also are plugged in to separate power sources, but I just can't get the fans to come to life.
3) The led read out seems to be working, the power and reset switches work, the usb ports are ok but the fan controller does nothing (probably tied to issue 2) nd the Hdd Led never lights up, I've checked the cabling to the mobo and all looks fine.
Any suggestions?
Cheers all
Any suggestions?
Cheers all
