I have just got back from uni for christmas and am sorting out our home network. We have just recieved a BT Home Hub and are connecting 2 pc (via ethernet) and 1 intel centrino laptop via wireless.
Queston 1: Setting up Wireless
I know very little about setting up a wireless connection so need some help. There are a couple of settings that I dont know what to change to, they are:
Radius I.P.: can this be 192.168.1.(anything) just as long as both the hub and the laptop have the same one (such as 192.168.1.5)
Radius Port: I am assuming leave this the same? (its on a port in the 1200's) and just copy over that port to the laptop I want to connect wirelessly?
And then the key, there doesnt seem to be an automatic generate button so I assume just input a random set of letters/numbers etc? Does it have to be a minimum/maximum length?
Then what encryption version? I know WPA is stronger than WEP but do all wireless card support this? If the laptop supports WPA should I use the PSK version?
And before someone says have a look in the instruction book, there pretty much is no book!
And the second question, One of the PC's is running vista and the other XP, how can I let the XP pc and the laptop see, browse and use files from the vista machine? I have already allowed sharing and set the folders I want to share to "everyone" in the sharing box on the vista machine but still cant find the vista machine on XP's network. Can someone point me in the direction of a tutorial so I can set this up?
Thanks
Thanks
