Man of Honour
- 17 Feb 2003
- Chelmsford
Firstly, when processing RAW files from Elements, what compression factor do you use or recommend? Setting 12 which is producing roughly 13MB seems a bit of an overkill? Should I stick to this or can I get away with lower?
Secondly, I need to print a few 8" x 6" prints for my assignment due in a few weeks. Can anyone recommended an online site that produces good quality prints they'd recommend? I've spend enough on equipment of late so a decent printer will have to wait.
Thanks
Thanks
