Couple of noob questions (PSU + 64bit)
14 Apr 2003
OK I've been out of the PC building lark for a while. My last build was meant to be an HTPC but it is far too big so lives in my office.
I bought the Antec Fusion case + PSU which I believe is:
Antec 350w 80+ PSU (Proprietary size)
This is powering an AMD X2 5050e, 4GB ram and 2 x 1TB hard drives. I have just bought an ASUS ATI 5770 - will the PSU be enough? I'm thinking no. If it is not enough, what will happen? Will it blow up my pc/face/house?
Also, I just read on here something about needing 64bit OS to make use of 4GB ram + 1GB of gfx ram. I run W7 32bit, I have access to 64bit for free but I guess I would have wasted my 32bit copy by activating it :( Will I notice a big difference?
Cheers.
I'd say the PSU isn't enough. If you were to use it and it wasn't enough power, worst case scenario it would set alight. It may power everything for a little while but then break, taking the CPU and mobo with it.
As for the ram, you'd be better off using a 64bit copy. You'd be losing out on quite a bit if you stick with 32bit but that probably wouldn't stop you playing most games. Also, if your copy is retail, you should be able to unistall it and re-install on a different computer? So long as it's not on more than one at a time.
OK, I probably wont risk the PSU, can you recommend me an adequate one? I'll probably be getting a new case too, so combos are fine.
Hmm, I got Windows 7 from the academic alliance, don't know if its retail, but I'm guessing not. I can probably get another CD key from uni if I have to though. I might have a mess with 64bit
And I say you need to install this into your car so it has enough power to haul your shopping bag:
http://i216.photobucket.com/albums/cc86/TastesLikeChicken_bucket/prime_mover.gif
as the new 5-series ATIs have low power requirements.
Mainstream graphics cards have never needed half kW PSU.
Worst case (FurMark) consumption of HD5770 is 80W with 60W being closer to actual gaming consumption.
http://www.xbitlabs.com/articles/video/display/radeon-hd5770-hd5750_5.html#sect0
