Greetings fellow folders,
I am slowly getting back to grips with Folding@home and have been playing around with the various different bits of software and options, I have a few questions . . .
Windows, SMP vs Multiple Console Clients
I have no problems getting the single console client set-up, I have done this for both cores on my Wolfdale HTPC. I had a go at the SMP/Deino software but found it a bit complex, I don't have a password on my account as I prefere my PC to boot straight to desktop with faffing around, anyway the question is what advantage is there to running the SMP instead on multiple single console clients?
At the moment two separate consoles installed as a service seem to be working ok?
-advmethods
Do you guys use this option? . . . I thought I'd give it a spin to see what is does, it's download some MAHOOSIVE WU called Translocon_GLX2 which seems to be taking forever to crunch . . .15 hours and I'm nearly halfway lol!
Not sure if its worth it point wise or not but I'll leave this -advmethods thing on for a week just to see how it acts etc. I was interested what your viewpoint on this advanced thing was?, I've also used it for the GPU client below, is that ok?
Windows, GPU Console Client
I was using the nOObling system tray GPU Client for a week and thought I'd give the console client a spin, all seems fairly straightforward but I was wondering, if I was to install a second graphics card how then do I set-up another GPU console client? . . . I don't see a way to specify which card uses which client etc
Overclocking your Folding GPU
The first week I was folding on the GPU using the system tray client I left the card at stock and all was fine, this week I thought I would apply a known working GPU overclock to see how that affected PPD . . . seems like the overclock isn't as stable as I thought lol!
Inbetween each failure above I kept downclocking the card to improve stability but it kept finding errors, in the end I have just put the card back to stock to get a few units crunched error free but I am suprised how sensitive folding is to overclocking. I was curious to know what your experiences have been with overclocking your folding GPUs.
-advmethods
This is the same as using the -advmethods flag. This will allow you to grab workunits with bigger requirements (often with more points value) than the normal units. Keep in mind this will often have a higher risk of failure so use this flag only if you are ready to accept the risks.
[00:58:59] Starting GUI Server
[01:05:05] Completed 1%
[01:11:13] Completed 2%
[01:13:03] mdrun_gpu returned
[01:13:03] NANs detected on GPU
[01:13:03] Folding@home Core Shutdown: UNSTABLE_MACHINE
[01:13:07] CoreStatus = 7A (122)
[01:13:21] Starting GUI Server
[01:19:33] Completed 1%
[01:25:36] Completed 2%
[01:28:00] mdrun_gpu returned
[01:28:00] NANs detected on GPU
[01:28:00] Folding@home Core Shutdown: UNSTABLE_MACHINE
[01:28:04] CoreStatus = 7A (122)
[01:28:19] Starting GUI Server
[01:34:26] Completed 1%
[01:40:29] Completed 2%
[01:46:34] Completed 3%
[01:47:47] mdrun_gpu returned
[01:47:47] NANs detected on GPU
[01:47:47] Folding@home Core Shutdown: UNSTABLE_MACHINE
[01:47:50] CoreStatus = 7A (122)
[01:48:04] Working on Protein
[01:48:04] Starting GUI Server
[01:54:15] Completed 1%
[02:00:21] Completed 2%
[02:06:28] Completed 3%
[02:12:34] Completed 4%
[02:18:39] Completed 5%
[02:24:45] Completed 6%
[02:30:51] Completed 7%
[02:36:56] Completed 8%
[02:43:02] Completed 9%
[02:49:33] Completed 10%
[02:55:39] Completed 11%
[03:01:45] Completed 12%
[03:07:51] Completed 13%
[03:13:57] Completed 14%
[03:20:04] Completed 15%
[03:26:11] Completed 16%
[03:32:18] Completed 17%
[03:38:25] Completed 18%
[03:44:32] Completed 19%
[03:50:39] Completed 20%
[03:54:56] mdrun_gpu returned
[03:54:56] NANs detected on GPU
[03:54:56] Folding@home Core Shutdown: UNSTABLE_MACHINE
[03:54:59] CoreStatus = 7A (122)
